2 pics attached. Edelbrock carb. I had the throttle return spring attached to a bracket anchored to a front manifold bolt. I don’t want that anymore. The spring went forward. Also shown is the throttle and kick down carb-mounted bracket that I want to use. I’m guessing that the “tab” on the bracket with the holes in it is for the return spring, but I don’t have a clue how it would work. Do I need some kind of additional fitting on the carb to have the return spring going back towards the firewall? Any advice, pics, part # would be appreciated. Angles on the pics are weird. Don’t know why. Thanks!
