Thoughts about my bbc combo
3.6K views 15 replies 8 participants last post by  CDN SS
#1 · (Edited)
Well i am knew on the forum and i am going to ask a question i have never asked.First what do you think of my combo.It is a .060 over 454 block 4340 crank with a 3.76 stroke 4340 6.635 long rod with srp pistons com is 10.7-10.8 brodix race rite rec port heads out of the box with smoothed chambers solid roller 256@50int 261@50exh .721 .685 lift .028 .030 lash the intake is a 2906 victor jr with 8082 1050 dominator.Please tell me what you think what kind of power do you guys think.Thanks alot Bill.
#5 ·
Interesting combo with the long rod .....does it make for a lighter piston?? Should make 600hp not sure about torque with long rod and single plane intake
The short block was bought from engine builder.He said long rod was to prevent side loading and it revs quicker.The motor was his personal he freshened it up with calico coated bearings arp main studs new arp 2000 rod bolts so i could not go wrong.It went 10.50s in the high 120s with 15 year old out of the box bb2 heads in a 3500 nova.
#14 ·
Good combination. I like it. It's going to want to rpm a little, but it'll make some good tq with the right cam. I agree with Chris...you'll need more ex duration with those heads.
You can also stand a little more compression with that long rod.
:thumbsup:
Scott
Can you help me understand why the longer rod can use more compression as opposed to a 6.135 rod
Iam thinking of upgrading my combo to approx 500" large bore short stroke( 3.76) pump gas .
OP sori for hijack ..........just never thought about CR and rod length
