Hey Jim, Those are awesome numbers, too bad you dont drive it on the street, would be a blast. Only if you have nothing better to do
, here is my combo as well:
468 C.I. Buildup
· Mark IV 4-bolt 454 Bored 60 thous over #3999289 casting w/ ARP main bolts
· KB207 25.5cc domed pistons
· GM “truck” thumb rods w/ ARP bolts
· GM steel crank, forged, cross drilled, 5140 steel #3963521 casting
· GM Heads 69-84 oval, open, '69 396/265hp, 366T, 427T, 112cc chamber #3933148 casting w/ ARP bolts
· Larger 2.19”/1.88” Dynagear Valves
· Bowls Blended and chambers opened to ~118cc
· Full port job
· Compression ~10.3:1
· ARP rocker studs
· Moroso 3/8” chrome moly pushrods
· Hi-Tech valve springs
· Comp Cams “Magnum” roller tip rocker arms
· Lunati Voodoo #60204 installed straight up
· Advertised Duration IN/EX: 276/284
· Duration @ .050 IN/EX: 233/241
· Gross Valve Lift IN/EX: .554"/.572"
· LSA / ICL: 110/106
· Holley 850 CFM double pumper w/ mechanical secondaries #4781
· Weiand “Stealth” aluminum dual plane intake (minor gasket matched)
· 1” carb spacer
· HEI distributor
· Milodon 5qt oil pan
· Milodon HV oil pump
· Comp Cams timing chain
· Hooker “SuperComps” w/ 2” primaries > 3.5” collectors
· 2.5” exhaust w/ Flowmaster 40 series exiting before rear tires
