My supposedly "tight" crankshaft, is crowding the limit on the loose side. Two journals are past the loose spec!
The only problem that I can see on my end is temperature. It was a fairly mild day (60's), and I had the heat on in the garage for 4 hours before I began measuring. ***The mic had been stored in the garage also, so it was the same temp as the crank.***
I realize that when measuring pistons in their bores it is essential that all parts be "soaked" in the same room for 24 hours before measuring, and the measurement be taken @ 70 deg F. How important is it (70 deg F.) in the case of a crankshaft measurement?
I'll also be checking my Starret mic against a standard today at work,
but wanted to ask this temp-expansion question too.
Thanks!
Mike
Update: Had my mic calibrated. It was .0002" off - it was reading big, so the crank is actually over the limit on the loose side.
Thanks!
Mike
