I see it was new for 1970. What exactly does it do?
Are there any benefits?
Are there any drawbacks to removing it?
As long as the manifold vacuum tree is connected to the transmission modulator valve and vac pot connected to the correct carb port the rest can be pulledMine is an automatic and there was no connection from the Atascadero to the transmission. 2 different post on the cab, one manifold and the other ported and the other end to the distributor.
There is a vacuum line that goes to the transmission but not from this valve. A hose goes straight from a port in the intake manifold to the transmission.
Keep the canister hooked up to control fuel smell. It also adds a little pressure on the vapor line. I’ve had fuel come running out on a steep hill when the nose was pointed down hill when parked with the canister removed. Its easy enough to put a T on the PCV Line or get a PCV with 2 ports to burn up vaporI think I’ll keep it. In a box for the next owner. Along with the fuel cannister…
