Taking It To The Next Level!
79K views 321 replies 52 participants last post by  40Coupe
Not a Chevelle, but I thought you guys might enjoy a thread like this!
After the recent performances of John Wilson and Garret (40Coupe) I decided it is time to take my shop car to the next level! So i thought I would post about the upgrades I'm going to try! Here are some pictures before I tore the car all apart!
Now For the Torn Apart Picture.........
Before I pulled the engine took a few measurments to see how much room I had to safely move the engine back in the car. I also did a bunch of math to figure out how much I could lower the engine and transmission to straighten the drive line angles out and allow clearance for a transmission shield inbetween the tunnel. After it was all said and done the engine can move back 1.5" and down .650", and on the new trans crosmember Im building im goin to lower the tailshaft of the transmission about 1.25" I designed the motor mounts to be light weight but strong. I drew them out on my CAD program and had them CNC Plasma cut out of 3/16" cromoly sheet and I tig welded them together. Because they are double layered there stonger than a moroso mount but not much heavier.
I mocked up the engine and new Turbo 400 transmission with its shield in the car using the new engine mounts and results were great. The only modification I had to do was change the lower control arm bolt to a button head allen and dimple the firewall where one header tube was close to it. Its amazing how nice the engine fits in the car moved back and down compared to stock. The trans shield fits real nice also. Atleast a 1/2" gap between it and the tunnel all the way around. When I had the engine and trans mocked up I also took a measurment for a new driveshaft. Then I pulled the engine and trans back out so I could fabricate on other parts of the car and not get grinding dust all over everything. The engine is also going on the dyno for some testing.
Here is the new driveshaft from PST
3 3/4" carbon fiber... 6 lbs lighter than my old alumnium 3.5" for the turbo 350 trans.
I also have gotten a new shifter for the new trans from Precision Performance Products it came with a new cable and real trick alumnium cable bracket for the trans. I had one of these shifters in my old chevelle and Ill never buy another brand shifter agin. They are super high quality and made completly in the USA.
Ill post more of the upgrades in the coming days... Im going to have the car ready to go to the track next month so I can see if it can hang with John and garret's times. So stay tuned!
#4 ·
.100" Alumnium sheared out to build a new custom fuel cell.
#6 ·
Pro Star 500 fuel pump so there will be no fuel delivery problems.
#7 ·
That is a super clean car last time I saw it! Great to see you're still playing with it and notching it up even more!
JIM
That is a LOT of fuel pump.....what are the plans?
#12 ·
Thats the pump I run on any of the cars I build. I'm very particular about how the fuel system is set up on a car. To me the fuel system in its entirety is one of the most important parts of car and how its goin to perform.
#10 ·
Tom, when you get it ready to race, are you going to take it down to Pueblo? All of us local boys would love to cheer you on. Maybe you could talk Jones in to a little grudge match. Your revamped Camaro against his Chevelle with the new "short stroke 990 headed monster". Now that would be a race!
#11 ·
Engines on the dyno... Time to find some more power!
#17 ·
Next dyno session should be interesting to say the least. Going to try testing indavidual cylinder timing and see what is worth. I have herd 1-3% gain is possible. Stay tuned!
#20 ·
Update - I have the engine making over 800 hp now and I still have some things to try!
#22 ·
I haven't had enough time to find any real power gains, but I was able to get the power, past peak power, to carrey out alot stronger. This was accomplished when I advanced the timing on the bad ports between 1 and 1.6 degrees.
#23 ·
Just ordered one of these... The guys at Star Machine are really honest and great to deal with. Hopefull it will be worth 2-3% hp gain
#25 ·
40Coupe, I know you run Afco shocks, Are they rite out of the catalog or did u have them custom built?
#27 ·
Thanks, Im trying to make a decision what way I wana go on shocks rite now. I know Afco is what alot of the fast guys run with stock suspension. Also looking at santuff.
#28 ·
Fuel Cell Parts
Machined chromoly tube for the fuel cell mount
Machined parts welded and ready to go on the jig plate
Mounting frame getting weldeld together
1 of the 4 fuel pump tabs
1" Solid Alum hex ready to be machined into mounting points on the fuel cell
After machining
#29 ·
Fuel Cell all welded (laying on its back)
Mounting frame all welded
Test fit in the car. I still have to build the battery mount, fuel pump relay module, and kill switch into the mounting frame.
#30 ·
Been awhile since I have posted, but I just got done dynoing for the final time tonight. I'm pretty happy with the results as the engine wasn't even on kill and now I have some really good, solid numbers, to go off of. The car is ready to take the engine and hopefully ready to hit the track soon with all the upgrades.
#31 ·
Wow...great powerband. TQ peak might even be below 4900 rpm and Hp is up at 6900-7000 and hanging in there. Someone has been working!
Congratulations!
JIM
#32 ·
Congratulations!
JIM
Thanks, Ill get some new pictures uploaded soon of the rest of the car.
