1 - 5 of 14 Posts
Been awhile since I fixed mine but if I remember correctly you just loosen the big phillups head bolts and you can adjust the position of the latches on the bed(not the tailgate).
Save
Save
Is that an aftermarket tailgate?
The fit on the sides is way off vertically on the driver side, and, I think the latch parts on the tailgate itself must be way off for it to be that loose!!!:confused:
Save
The part of the latches on the tailgate are not supposed to be adjustable, only the ones on the bed.
I have seen many elkies where the tailgate wasn't centered between the bed sides but I haven't seen any with a vertical alignment problem like that. I would compare the sides of the tailgate to see if they are parallel/square, if they are then the tailgate should be ok. If the tailgate sides are paralell/square it looks like the bottom of the tailgate is too close to the driver side bed and it needs to be shimmed or otherwise tweeked toward the passenger side.
Check the bed sides to see if they are parallel/square too!!! Maybe the driver side quarter has been replaced at some point in time and was not correctly installed.
At any rate you've got some work to do to match everthing up!!!
Save
both quarters were done we did them and used full quarters. would the shims go on the tail gate where the hinge bolts on or on the bed side of the hinge? this is the first el camino we have done so thats why all the questions
I put them behind the hinge bracket on the bed side of the hinge. I also had to heat and beat the bracket on the oposite side a bit to get it perfect.
Save
1 - 5 of 14 Posts
