Tach not working
10K views 17 replies 7 participants last post by  454s4ever
I have seen a lot of posts about tachs not working when switching the HEI dist. I have the same issue. Installed new motor with HEI, American Autowire harness and the tach would only move between 1000 and 1500 RPM. I bought a tach filter and installed it. Now the tach sits at zero and doesn't move at all. Any suggestions?
#4 ·
My understanding is that the tach filter will make the factory tach work with HEI.
I installed the tach filter in line and plugged it into the tach terminal on the Distributer.
What I don't know is if there's different tach filters and if I just got the wrong one.
#5 ·
Did the tach work before you installed the HEI? What make of HEI?
Really look closely at the connector on the HEI. If you miss the male pin or it is bent,, it will not make contact properly.
#7 ·
I got the filter off of ebay but I don't remember from what company. Are there different filters? Maybe I bought the wrong one.
It has the in and out wire. The body of the filter has a mount that I bolted to the intake. It's an aluminum intake but that should be good enough for the ground right?
#16 ·
Sorry. I read back through the string of posts and here's answers to the questions. Let me know if there's anything else you need to know.
The tach did previously work prior to the HEI ignition install.
The distributor is a Street Fire HEI by MSD part number 8362.
The tach filter I bought is for a 75 - 89 corvette (gm# 14020025).
It is bolted to intake so I think the ground is ok.
My tach is the factory tach.
I did just finish restoring the car so I'm wondering if maybe a wire behind the dash is not right. I will check the ground behind the gauges.
Thanks again
#17 ·
What fixed the problem? I have a factory tach in a 69 Chevelle using factory wiring harness going to a stock HEI distributor and my tach reads about half the the RPMs. Once it gets to about 18-1900 it really wont go any higher. I have researched the tach filters and don't mind buying what it takes but hey that's what these forms are about right? ANy help would be appreciated.
