Hello team and thank you in advance. The engine is 383 stroker, and I was running a dual plane intake (Edelbrock air gap) and 670CFM Street Avenger carb from Holley.
I swapped to a Team G single plane intake and 750CFM double pumper from Holley. I dropped the distributor back in the same place and fired it up and I took it around the block. It was like night and day and the car was really responsive. Since the initial start-up, the car will not fire or turn over. with the new single plane intake and carb, does this create vacuum issues? Is there any suggestions I can do to get my car to turn over? It's cranking but the engine will not fire up.
Thanks,
Anthony
Thanks,
Anthony
