The problem is the location of the shift arms on the Camaro‘s Saginaw 343 are positioned to far back to use with my column shift linkage. The Camaro trans I have came with a a 3 speed shifter - but the shifter requires mounting to the transmission crossmember. My Chevelle crossmember has no mounting point for this shifter. Is there a possible fix to this problem - or will I need to purchase another shifter that mounts to the transmission case ?
