HI
i have 4 wheel LS1 disk brakes that i want to put on my 72 chevelle. i am pretty squared up with mounting them, but i had afew questions...
whats the best size master to use?
is a prop valve necessary on the rear line?
i keep the metering valve, correct?
do i have to run any new hard lines? if so, which ones
the rear brake ebrake, has anyone been able to get this squared up asside from a custom cable?
i just need an adaptor to make the metric brake lines to the std fittings?
i searched, but i am still unsure on a difinitive answer for this
thanks
mike
thanks
mike
