Sorry Dave, I missed the adjustable arms portion of your first posting. Did you also to the tall ball joints with those? Reason I ask is that with wide tires, and this is compounded by low profiles, there is no way with the stock A-body front end to not kill the tires. As the suspension compresses the tire goes from negative camber to positive camber. So you are never really at the *no* camber condition needed for optimal tire life.
There is some benefit in positive caster to pull the top of the tire in as it is rotated for steering. Apart from generally being extreme, I believe this is what Dennis (aka sinned) was trying to do with his 9* of caster. Due to the minimal camber benefit, I would go with the 5* caster.
Now if you do not have the tall ball joints, you are probably going to need to increase tire pressures up front and run more negative camber. This is a kludge to try and balance the wear patterns. Natural wear is concentrated on the outer edge. Negative camber will add more wear on the inside edge and higher tire pressure more wear down the middle. You should need very little toe, probably about 1/8". These recommendations are biased towards tire life.
For performance you want as much of the tire on the ground as possible. But here again you have to compromise between emphasizing straight ahead traction or loaded cornering traction. The former will need less negative camber then the latter.
Hopefully that gives you some idea of what I am basing my prior comments about alignment depending on driver/driving style. After running through a set or two of tires and watching the wear patterns you can get an idea of where you need to make adjustments. For reference I am running about 3/4* negative camber and 2-3* of positive caster (all I could get) on my otherwise stock front end.
