On our 70 (as well as our son's 68)-----------------WHICH I BELIEVE TO BE CORRECT------------------ after the speedo cable comes through the firewall, and goes down under the car, it passes UNDER the front of the Muncie case, to a spot welded clip on the RIGHT floor and curves over the the speedo fitting on the tail housing.
There was a clamp attached to the left, lower bolt, attaching the Muncie case to the bell housing to retain the cable in place.
The first picture is our 70 conv. The next 2 pictures are our son's 68.
On our 70, I fabricated a second clamp for the bolt on the right side which tucks the cable up a little more, and further from the header.
