1 - 3 of 16 Posts
gotta watch those rails, if the ring compressor comes up off the deck at all they will pop out.
Can you post a pic or link to a pic? Honing is not a very good solution, you would need a ridgid stone, the stuff gets all over everything, have to tear-down and re-clean, all that.
Any detail on the fingernail catching deal? Especially, can you determine if there's scratch *into* the wall or is there a ridge pushed up on one side of the scratch? If there's a ridge it has to come off, it'll wreck your rings and maybe the piston. If it's a carved out scratch you might get away with it.
What type of engine is this? stocker, race, somewhere in between?
looks like you can still see the hone marks under most of the scrape? where can you feel the scratch?
What Al said, thanks for the results.
Are you using a tapered sleeve ring compressor? Or some kind of one where you tighten up a band some way or the other? I recommend the tapered sleeve deal.
1 - 3 of 16 Posts
