Bought a set of Scorpion 1.7's to replace the Crane Energizers (Silver) I have been running. They appear to be a well built rocker. A little heavier than the Crane Gold we compared them to, but most of the weight seems to be in the trunnion area, so don't think this will cause any real issues. Of particular note is the diameter of the roller tip which measures .600" diam. Did mock up on Vince's 509 with the AFR heads. Not sure if it's the effect of the large diameter roller, but the pattern across the valve tip was wider but centered. Pics will follow..
[/QUOTE]
