veltboy314
Discussion starter · #1 ·
I"m thinking about doing a mild rebuild on my engine. I want to change the piston rings(maybe), rod bearings, main bearings, Cam & lifters. Everything else I am going to reuse if it's good when I take it apart. It has been rebuilt before but I have no idea how long ago that was. It runs real strong but I want to go through it over the winter.
Its a 010 block & the heads I have right now are stock. the casting # is 462624. I plan on upgrading to a set of vortec heads soon. Which ones will be best on my 355?
What would be a good cam for this engine. I'm just looking for a nice cam that I can drive on the streets & it will produce enough power to win a few street races.
When I order the main bearings is there a certain kind I need to get. What i mean by that is do they come in different thickness. If so. how do I figure out which ones I need.
I know it was more questions I wanted to ask but I can't think of them right now. I'll add them later.
Darius:
Do a compressoin check on the motor before tearing it apart. If it checks out good, then I would suggest rather than pulling the motor down, upgrade the cam and heads. No need, imho, to rebuild it if it doesn't need it.
HTH,
Durand
If it runs real strong now, then why do anything?
However, I like Comps. 256H for a mild 355. In my 4000lb. truck this is the only cam I have found where the truck will bark the tires when it goes into and comes out of passing gear, and every time it changes gears. Around 3000rpms.
If, I were to use it again, I would order the cam with a tad earlier intake close point to help with a slight amount of reversion. And it is not big, by any means. But it does create a slight lope.
I feel a 1800 converter would be a good addition. But a stock stall works just fine.
1 5/8" headers with 2 1/4" exhaust with an X pipe, works for the exhaust.
This cam needs 18 degrees initial timing, with inverted dome pistons, too. It idles at 750rpms. and will pull strong to about 5600.
PS. I have tried nearly every one of Comps. Extreme energy grinds in this engine from the XE250H to the XE274H. I like the 256 best overall.
I've been getting around 18mpg. here lately.
