madtech
Discussion starter · #1 ·
When applying the brake pedal softly brakes work ok
Apply some what harder the front right lock up
Here is what I have done replace front calipers, both front hoses,
Right side metal line, proportioning valve, swap both rotor & pads
Master was replace
Im going to replace left front metal line this week end
Help please
The question is, is the right front grabbing or the left front not working and causing excessive pressure to stop. Try jacking up the front end and with light pressure on the brake pedal rotate the front wheels. See if you can tell.
Discussion starter · #3 ·
this weekend i install new line to right side now all metal lines hoses are new
i did try what you recomended had my boy push on the pedal till some drag
both caliper are under pressure and slowing the tires aprox the same
one question if one of my brake caliper braket is bent will this couse this problem
i dont think they are bent
Sounds like the opposite side is actually the side thats causing the problem. I would check the hose and caliper itself, the slides, etc.
