REVISED 5/1/06 Bad Cams/My Info To Hopefully Reduce New Cam/lifter Fails
178K views 281 replies 91 participants last post by  LevonH
Since i have seen another 3-4 more cam failures here in T/C over the past month or so i thought i would re-post my UPDATED VERSION of my original post on trying to prevent or at least reduce the chances of NEW CAM FAILURE which includes some additional items & some new info too.
Please feel free to coment and or add any additional info that may be helpfull in preventing a cam failure for anyone installing a new cam here in T/C.
Scott
Some important things for new cam installs that are not always done or even considered that are " MUST DO PROCEDURES" for all my cam installs which i feel are vital to avoiding new cam/lifter failures. (See below for replacing a bad cam with the motor in a car without tearing the motor down for cleaning and insp of bearings etc.) This is a last resort thing to do which i don't recommned but it can be done successfully if done properly in many cases as i state below.(SEE BELOW THE CAM INSTALL PROCEDURES & DIRECT LUBE LIFTER INFO FOR THE DETAILS OF REPLACING A CAM WITH THE MOTOR IN THE CAR)
NOTE;MY CAM INSTALL PROCEDURES ARE FOR STOCK/MILD/TO FAIRLY HOT FLAT TAPPET HYD (HYD ROLLER TOO JUST TO BE SAFE)/SOLID CAM INSTALLS IN SBC & BBC AND THE USE OF LIGHT PRESSURE VALVE SPRINGS FOR CAM BREAKIN IS "NOT REQIRED". BUT FOR HOT/LARGE HIGH LIFT LONG DURATION ALL OUT PERF CAMS WITH HIGH SPRING PRESSURES AND HIGH RPM USESAGE THE USE OF LIGHTWEIGHT SPRINGS FOR BREAKING IS REQUIRED.
* FRESH 10w-30 (or 30wt if warm enough) OIL & FILTER (long style AC PF35 or equivilent) prior to startup.
NOTE: SHELL ROTELLA OR CHEVRON DELO 400 OILS ARE GREAT OILS THAT ARE USED FOR DIESELS THAT COME WITH ADDITIONAL ANTI WEAR ADDITIVES THAT BENEFIT FLAT TAPPET CAMS THAT ARE NOT IN MOST OF TODAY'S GASOLINE MOTOR OILS.
* Always use a Filtermag (Very strong magnet) on the oil filter to trap metalic debris.(See Filtermag website for details)
The Filtermag is pricey at 50-75 bucks but its cheap insurance/protection against a bad cam in your new $3k-5k motor/investment by trapping any metal contamination from the oiling system in the oil filter.(See Filtermag website for details,i think it's a great product IMHO)
* You can also remove the oil filter bypass valve and plug it with a pipe plug(either 1/4 or 1/2 inch plug?) to force all oil through the oil filter. But keep in mind to never rev the motor up too high untill the motor & oil are up to operating temp or you could distort or blow the oil filter altogether.
* VERY IMPORTANT to inspect the cam lobes and lifter bottoms very well with a magnifying glass for any imperfections that look like they could scrape or dig before installation. If any imperfections are found on cam or lifter/s either use crocus cloth to smooth the rough area/s out or replace the cam or suspect lifters,if needed show to machinest for advice.
* Lube the cam lobes with a lot of moly lube(I prefer Crane's version) including the fuel pump lobe/ecentric & dist gear.
Note,DO NOT USE THE RED COLORED CAM LUBE LIKE COMP CAM USES,IT'S TOO THIN AND RUNS OFF. ONLY USE THE GREY COLORED MOLY LUBE LIKE CRANE CAMS USES WHICH YOU CAN BU SEPERATELY FROM THEM,THE RED STUFF IS NO GOOD AT ALL.
* Also,VERY IMPORTANT to put some moly lube on the camshat inbetween the lobes .This so when the motor heats up the moly lube inbetween the lobes on the shaft will thin out and be thrown off as a mixture of oil & moly lube back onto the lobes & lifters. The cam & lifters are lubed/oiled by oil thrown off the crank and from oil pumped to the lifters and oil thrown off the cam while it's spinning too.
Note-do not use the moly lube on the cam bearings,only use std motor oil for the cam bearings.
* Put plenty of moly lube on bottoms of lifters,no moly lube on sides of lifters,use only oil there.
Note-check lifter bores for scratches,dings,etc and if any questions show to a reputable machinest to verify ok to use before assembly. You may be able to use crocus cloth to clean up any rough lifter bores with the machinests approval.
* See below(bottom of cam install info) for my take on the DIRECT LUBE LIFTERS.
* Pour plenty of motor oil over the chain & sprokets.
* Use moly lube on the pivet balls in rockers but only use motor oil on the pusrod to rocker interface as the thick moly lube can impead oil flow to rocker at startup esp if its cold out.
* VERY IMPORTANT to adj valves with intake off. This is because when you adj the valves at least half the moly cam lube is wiped off the lobes while doing the adj and it MUST be re-applied post valve adj or you are asking for trouble. I use my finger/s and any other smooth item i can find to reach through the slots on the block to re-apply the moly lube to the lobes you can get to,this is very imprtant to do and is almost always overlooked.
* After you re-apply the moly lube to the lobes post valve adj pour a bottle of either GM EOS or Crane engine break in lube over the entire camshaft where ever you can through the slots in the block and through dist shaft onto cam gear too. This is added start up protection and the ballance of it will go into the oil pan. Also pour a little onto the rocker arm pivot balls.
*After motor is assembly is complete prelube motor with correct tool that seals off dist shaft for proper prelube of lifters,etc. Remember to rotate motor while doing pre-lube.
* Fill coolent (50/50 mix of antifreeze & distilled water) through thermostat opening in intake. This is so you can push out all the or most of air in the block. This also allows you to fill the coolent up to the point when it alomost overflows the intake so it will contact the thermostat for startup. This eliminates the BIG PROBLEM of overheating the motor before the stat opens because there is no coolent touching the stat,only air and the stat takes much longer to open this way thus overheating the motor and oil in the process. Use a 180 high flow stat too.
* Have a 20 inch box fan(2 if poss) running full speed set high enough to blow cool air directly into the radiator for the entire cam breakin period. This will help a lot in keeing things cool for cam breakin. Have the car out doors if possible for better fresh air flow during cam breakin.
* Pre fill the carb if possible to minimize cranking prior to startup which could wipe most of the moly lube off the lobes/lifters before startup which is not a good thing.
* Make sure to get the timing right the 1st time so it fires up fast with minimal cranking time.
* Uppon startup get the motor to approx 2200-2500 rpm ASAP (min of 30mins-max-40 mins) and crank in plenty of intial timing to avoid retarded timing that will make the motor run much hotter than it normally would. Remember the stock timing specs are no good when using any type of perf cam. Most mild to hot perf street cams need apporx 14-18 deg btdc intial timing (with vac adv plugged) to avoid being too retarded. Timing does not have to be set perfect for cam break in,just make sure its not too retarded or motor will run hotter.
Note - Keep an eye on the oil pressure during entire cam breakin period as the moly cam lube can at times (though not often) partially or fully clog the oil filter
which will result in a small or drastic drop in oil pressure. If this happens and the oil pressure drops below lets say 30psi @ 2500 rpms i would shut it down and change the oil filter then proceed with finishing out the ballance of the cam breakin time period. I would use an AC PF35 truck filter(or equivilent) that has the extra capacity to help avoid a moly clogged oil filter. I would not recommend Fram oil filters as they have been noted in the Team chevelle site for collapsing when oil filter bypasses are blocked off and also for clogging easily with moly lube durring cam breakin according to members on the site.
* After the 25- 30 min cam breakin is completed shut it down and change the oil and filter on the spot while the oil is hot and all the contaminants are still suspended in the oil.
Note 1-use 10w-30, 30wt (if warm enough),or Shell Rotella T 15w-40 & another bottle of gm eos or crane motor breakin lube/and the filtermag for this post cam breakin oil change. Run this oil only 200-300 miles max and change the oil & filter again,then return to your std oil change schd & oil you normally use along with your Filtermag.
Note-2 ;Another late entry,use Chevron Delo and Shell Rotella Diesile(SP?) 15w-40 oils if your running a flat tappet cam because they have the most anti wear additives in them when compaired to most of todays oils which have removed the anti wear additives of the past that are vital to the longjevity of flat tappet hyd/solid cams esp when running higher spring pressures. I contacted the Shell engineers through their website to ask them if the their diesel oil was ok for use in our muscle car motors and they highly recommend the 15w-40 Rotell T for any older SBC/BBC muscle cars running a flat tappet cams because of the additional anti wear additives for the flat tappet cams and it great shear resistance that the big rig motors need pulling heavy loads.
Scott
Save
#24 ·
Re: REVISED 5/1/06 Bad Cams/My Info To Hopefully Reduce New Cam/lifter Fails
Bob,syn oil was not touched on in my info or the Hot Rod article because for yrs synthetic oils have not been recommended for cam breakin by the cam mfgs for various reasons.
Also,many times new cams are being broken in the complete motor is new too and syn oil is not recommended for most of our older motors for fire up & over all breakin. This is because syn oils can impead or completely stop the rings from seating properly resulting in burning oil where as std oils dont have this problem.
Scott
Save
#23 ·
One other question that you haven't touched on nor has Hot Rod, what about synthetic oil? I use Mobil 1 in my daily driver (overhead cams) that's running great after 130K. It's supposed to be a great oil but if it doesn't have the additives for flat tappet cams then I won't use it in my new 454.
#22 · (Edited)
BondoBob,yes i had seen that done in a magazine article a few yrs back which made sence but with the ZDDP anti wear pkg being removed from most all std pass car oils thats wear a major problem exists.
It's not always a lack of oil getting to the cam,it just plainly an issue of the ZDDP anti wear additives crucial to our flat tappet cams being removed from most all of todays std pass car motor oils.
But if all is correct in the block,the lifters & cam are inspected to insure they were prepaired/polished/machined correctly with no defects/dingd,etc,cam is installed & lubed properly with moly grease/paste,motor is prelubed propely,and a motor oil like Chevron Delo 400 15-40 that has the additional anti wear additive pkg ZDDP and moly crucial to protect flat tappet cams from excessive wear is used esp durring breakin along with GM EOS or Crane engine breakin lube,you should be ok and not need that oiling modification unless your running a wild hyd cam with very high spring pressures.
I think its a combination of things that have lead to some of the flat tappet cam failures we have been seeing here in T/C. Things like not paying attention to detail when it comes to cam install (esp if inexperienced in cam installes) like checking the new cam & lifters for defects/scratches/dings prior to install,not using a motor oil like Chevron Delo 15-40 with the ZDDP & Moly anti wear additives to reduce valvetrain wear that are crucial to flat tappet cams along with not using GM EOS or Crane breakin lube poured over the cam/lifters into the crankcase during cam install that can lead to cam failures. And also not using the Chevron Delo 400 15w-40 oil post cam breaking to ensure valvetrain is protected at all times.
Any one or cobination of these things can easily lead to cam failure esp with most of todays pass car motor oils not having the ZDDP anti wear pkg crucial to reducing valvetrain wear in motors with flat tappet cams.
The problem is i have read the government has put stricter EPA controls on Deisel engines that is going to force the oil mfgs to reduce the ZDDP anti wear pkgs currently found in all the Deisel truck oils like Chevron Dello 400/Shell rotella T/Mobil Delvac 1300 all 15w-40 grades possibly as early as 2007.
Thats because the ZDDP anti wear pkg supposedly add some plutants to the air and will prematurly foul cat converters that may be installed on Diesels in the near future.
Hopefully Valvoline will still offer the 20w-50 R1 racing oil with the ZDDP anti wear pkg 2007 & after that.
There is also "Joe Gibbs racing oil" (#20 Home Depot/Tony Stewarts Boss) that specially formulated with the additional valvetrain anti wear pkg crucial to flat tappet cams which can be bought on the net from his website for a small fortune.
So stock up on the deisel oils now while you can before 2007 hits.
A couple $100 worth of oil will last us wk end warriors,Frid & Sat evening cruise crowd types ,or Sunday carshow types many yrs without worring about having good oil with the ZDDP nti wear pkg to protect our flat tappet cams from excessive wear.
I guess if all ZDDP & Moly anti wear pkg's are removed from all motor oils in the future hopefully the GM EOS or Crane Engine Breakin lube will be available
to use with each oil change. But i have read the additive in those items can lead to premature carbon/soot buildup in cylenders esp if the motor uses a little oil .
Scott
Save
#21 ·
What do you think about the "Oiler" that was added in the Chevy Off Road.com project Potent Rodent? They tapped into a oil gallery and ran a 1/4" copper tube, down the valley area, that had .030" holes drilled in it directly over each lobe. If that doesn't supply enough oil what will? The only negative I could think of was that all the pressurized oil might wash off the cam lube during break-in.
#20 ·
Chris,you cant get all the metal debirs out of the motor when its in the car by flushing it out,you can hopefully get the majority of it out at best.
But,as i stated from working on motors over 35yrs i have replaced many a bad cam in SBC & BBC over the yrs and never had known of a problem later on with bearing/s going bad and causing a rod/main knock etc.
Thats not to say a couple hadn't failed a few yrs down the road after the person sold their car and i was not aware of it. But even if there were a couple failes down the road more times then not things were fine on the mild to stock perf motors i have done this on in the past.
But none were 700hp grond pounding motors,they were either stock or mild perf motors to approx 400-425hp max. High hp motors that had metal debris from bad cam already through the bearings may not have tolerated it and spun bearing/s etc. I was dealing with stock to mild street perf motors when changing bad cams with the motors in cars.
You can either believe it or not,i am just pasing on my 35+ yrs of 1st hand experience with working on & replacing worn/bad cams in SBC & BBC.
Scott
Reactions: temp2c
Save
#19 ·
SWHEATON said:
(See below for replacing a bad cam with the motor in a car without tearing the motor down for cleaning and insp of bearings etc.) (SEE BELOW THE CAM INSTALL PROCEDURES & DIRECT LUBE LIFTER INFO FOR THE DETAILS OF REPLACING A CAM WITH THE MOTOR IN THE CAR)
I dont see this... how do you get the motor clean of all the metal from the wiped cam lobe while the motor is in the car?
#18 ·
Swheaton, thanks for the awesome thread!!
I've printed it off, and will be following it to the 'T'. Unlike Ed's buddy with the now bagged cam. One question I do have, is you mention rotating the engine when priming. Could you please tell me exactly what, when and how this is done. I'm getting too deep into this rebuild to risk grenading it over something simple.
Totally appreciate the advice. It's been 20 years since my last motor, and it sounds like the oils are nothing like they used to be.
Tks, OC:thumbsup:
#17 ·
If Your Running High Srping Pressures On A Flat Tappet Cam I Would Say Yes To Be Safe.
If The Cam Is Hot Enough To Require Dual Springs To Keep The Valves From Floating At High Rpms Past 6k Rpm I Would Think That Would Justify Removing The Springs.
I Know Its A Real Big Pia But Bteer Safe Then Sorry With A Wiped Out Motor Later On From A Bad Cam.
Opps,sorry About The Caps,wasnt Watching.
Scott
Save
#183 ·
Read Hot-Rod magazine article June 06
"Why Good Cams Go Bad"
It answers all your questions,
hi guys.if i could offer an opinion:i agree with every bit of advice given on this subject to successfully get through a flat tappet break-in and the people offering this advice are absolutely on the mark. here is what i learned when the world changed 5 years ago and nearly bankrupt me: i can follow every step here for a perfect break-in under ideal dyno conditions and still wipe a lobe two months later in the car after 50 dry starts after a week set in the garage. the bbc especially will fail a flat tappet cam( poor lifter bore geometry, big rocker ratio, agressive lobes for power, big spring pressure for agressive lobes ) even with an american lifter with the perfect zinc-phosphorous package oil. please think about this: work some more overtime; sell some old parts; siphon gas from your nieghbor, but wait until you have $500 and upgrade to a hydraulic roller even if means waiting an extra couple of months to assemble your engine. the world has changed drastically in 5 years and you aren't doing anything wrong to fail a flat tappet cam today. today isn't yesterday. i never wore a flat tappet cam in 20 years, but i wore out 9 in a year-different engines, all manufacturers etc. the only way to have a shot at success is no spring pressure on the mildest lobes with positive oil feed lifters. if this appealled to anyone here they wouldn't be on this site.learn from my costly education. thanks for listening.p.s. my equivilent hyd. roller cams pick up 25hp&torque at all rpm's and 2 inches of idle vacuum to help your brain justify the extra ching!
#14 ·
Thanks Swheaton And Everyone For Info On Cam Break-in!!!
I Know Lubrication Is Every Thing And Its In The First 30 Min Are Critical For Cam Life. Something About Metal-to-metal Contact Just Doesn't Sound Good In The First Place, But What Is Really Going On There? Is It Something Like Seating Valves And Piston Rings? Whats The Deal?
Thanks Mr. Blue
Save
#13 ·
Whatever happened to good old Lithium grease, ya know, the white stuff?
Reactions: temp2c
Save
#12 ·
Chad,your mighty welcome,i am glad you and hopefully others are getting something out of the cam install/lube/breakin info i put together for our team memebers. I did this in hopes of avoiding or at least reducing failures of stock to fairly hot (not wild) hyd/solid flat tappet cams most of us are running in our street machines.
Scott
Save
#11 ·
Scott,
Thanks a million for the post and the information about Comp Cams red lube. I started final build on a motor the other day and didn't like the idea of using the stuff. I called Comp Cams to check on it and was on hold forever. Meanwhile I called Summit and talked to one of their tech guys who assured me it would be fine. Problem is it is going to be some time before I fire this motor.
Red stuff is coming off; moly lube is going on.
Thanks again.
#10 ·
Hey guys, If you're into building engines or changing cams with the engine out of the car (I agree with SWHEATON) take a look at SUPERTUNE engine hotstands. www.hotstands.com I work out problems on the stand and you can run valves hot without getting oil all over the engine compartment or dingin up a fender. I dont install an engine in anything anymore without running it on a hotstand first
#9 ·
You dont have to prefill the lifters but i have always just soaked them overnight in a qt of motor oil prior to install.
Some would not aggree with this but i have done it on every cam install iv'e done in 35yrs with not a single failure so it works for me.
I am not totally sure of how much it helps to do this but i feel it has never hurt me to do it.
But i wipe the oil off the lifter fasce just before you apply the moly cam lube for install so it sticks and doesn't slide off if applied on top of the oil film.
Scott
Save
Scott
Either I am too tired and missed it or it is not in your article. Do you prefill the lifters?
Tom
Save
#7 ·
I would also add: prior to final assembly, rotate cam by hand with lifters and cam lubricated with just oil to verify that all lifters will spin.
Also GM part # 12345501 is their Cam and lifter lube 4oz, get 2.
After initial break-in, with engine idling and valve cover off, verify that all pushrods are spinning.
G
#87 ·
Good, this what we do, Mark
#6 ·
SWHEATON said:
FYI,UPDATE ON GM NOS,I recently read here in T/C that GM changed the makeup/ingredients of EOS and that it states on the container not to use in the crakcase anymore so dont pour into your crankcase. I read this in more than one post from different people so i believe it's true.
I would still get some Crane engine breakin lube which is very much like the old GM EOS and pour that over your cam & lifters prior to installing the intake to aid in fresh motor startup/breakin.
Scott
Here is what I understand the deal is,,,
GM doesn't like lawsuits or the EPA fines that go with an "oil additive" that doesn't meet their requirements,,,
If it is an "oil additive" it has to pass EPA requirements regarding zinc,
phosphorus,,,,, blah, blah,,,,,
If it is an "assembly lube" I do believe different rules apply :rolleyes:
Still good stuff, still smells like crap,, still my favorite,,
I also like the Crane stuff
Don't know anything about the new Comp stuff.
#5 ·
Scott
Save
#4 ·
Ah yes. My buddy was installing a brand new cam in his small block Beaumont, so I took the time to reprint your warning and methodology. I said, "Do not deviate from this one iota". Ok Ed, we won't.
Fast forward three months to last week. Brand new cam wiped out. I questioned them on their methodology: did you follow to a T? No reply. It does not serve them right, but it is damn unfortunate that people will just not listen. Unbelievable.
Reactions: MikeM's 65 BBC
Save
#3 ·
I't doesnt surprise me that comp cams admitted that their crappy red watery cam lube runs off in 1 week. This shows comp cares most about the $ and not as much about their customers because they know about the shortcommings of their red cam lube but dont step up and supply the superior moly based lube that stays put but likely costs more money with their cams.
Maybe they/comp figured it costs more to supply the better moly lube with every cam than to replace X amount of bad cams yrly that they can write off as losses,it could be as simple as that.
But it doesnt cover or account for all the lost time/money/and effort on the muscle car enthusiests part after all the metal from a wiped cam trashes a new motor which really burns me up.
This is like shooting themselves in the foot when it comes to bad cams because many people install the cams in new motors and dont fire them up for wks or months and that red lube is long gone according to what the comp cams tech rep told you which could be a real problem esp if they crank it over too long before is fires up. I am sure a certain percentage of bad comp cams is caused by their inferior red lube running off the cam/lifters prior to startup whitout the user/customer ever knowing it.
Scott
Save
#2 ·
Very good advice about the breakin lube. I used the red Comp Cams lube on my XE268. I took three days from "lube on cam in" to fired up. My brother was building a new 383 using an XE262, I called Comp because I knew it would be at least a few weeks between cam lubed and in and when the motor fired for breakin. Comp actually recommended the Crane moly lube. They told me if it was going to be longer than week from cam lube and in to fired up you had to use a moly based lube. The red stuff will drip off and offer your brand new cam no protection for breakin.
