So as I sit here reading the various posts of folks accusing Brand X cams of being bad, or blaming poor preparation for issues, or saying make sure to do this or that prior to actually firing up for the first time, I begin to wonder and worry about things (again).
We recently got our BBC back from the machine shop and re-assembled it, taking great care to properly goop it up with a good quality assembly lube in all the right places as well as making sure everything was torqued properly and all bolt holes were retapped and the threads all clean and clear. Everything was oiled and we even went so far as to lube the bottom of the lifters in addition to the cam lobes.
When it comes time to actually fire this beast up for the first time, it will likely have sat assembled and sealed up for 6 months or so. With a good thick and resilient assembly lube and plenty of pre-lubing/pre-oiling, what else can one do? This is a hydraulic non-roller lifter motor with an aftermarket "Brand X" moderate street cam and heavier than stock springs. Our machine shop did the head work and assembled the valves and springs, but we re-assembled the motor. It's clean, it's tight and it's lubed...
Is there a good reference for the start-up process? How would YOU do it to have the utmost protection from potentially wiping a lobe and ruining our day?
getting worried...
getting worried...
