New to this site.. i have a 67 chevelle. Alston non adjustable lower control arms single adjustable uppers. Had moog stock springs switched to Eibach lowering springs with air bag in passenger side. 9" rear end out of a bronco or something with the ears welded on from old rear end... Shocks are edelbrock IAS.
The problem i am having is the passenger of car in the rear end sits about a 1" higher then the driver side. this also cuases the driver side front to sit lower then the passneger side front..Front has moroso drag springs. It was the same with the stock springs as the eibach springs. The control arms have rubber bushings. I am thinking that the passenger upper may be in a slight bind.. i have tried lowering rear end with shocks undone and passenger side sits lower then driver side. Also treid having front end up and off tires to see if the front suspension is infuenceing rear susp. it is still crooked.
Has anyone tried putting spherical bushings in a street/Strip car on the upper ears of rear end for the control arms? and would this help the problem? Any other feedback would be appreciated. I am looking at the TRZ spherical bushings they said they have a teflon lining on them that help with wear...
thanks
Corey
thanks
Corey
