storm
Discussion starter · #1 ·
hi 70 chevelle put in rear control arm bushings in now ready to re install rear how tight do i tighten the bolts ? any specs? do i tighten them where they dont move?? tighten them while i have the jack under the rear?? thanks storm
You have to torque RUBBER bushings with the axle at normal ride height.
Polyurethane bushings can be torqued with the suspension in any position.
Yet another reason to use Poly.
Save
Yeah, as long as you don't mind suspension that doesn't work.
Although I HATE poly, he is correct, only rubber bushings must be torqued in the loaded position to prevent preload.
Save
