The potential of basic GM production parts is the subject of this test. Theres allway a lot of controversey on dyno numbers, but this is a basic build I would like to share with this forum. 4.280 X 3.998 460 cu in, GM 959 454 block, Scat 9000 crank, GM truck rods, Mahle pistons 10.5 compression, Isky 560 lift 254 @ .050 108 installed 103, Ported 049 GM oval port heads, Ferrea valves, Smith bros pushrods, Scorpion rockers 1.7 ratio, RPM air gap intake, 850 holley (4781) 35 degrees total timing 91 octane pump gas, moroso 20403 oil pan, 5.5 quarts of Gibbs XP4 oil. This combination would easily push a full weight Chevelle well into the 10 sec range.
