Has anyone tried "restrictor pushrods" to control valve float on a hydraulic roller? Just curious.
If the pushrods restrict oil flow by means of an orifice, that will in no way affect the mass of oil in a hollow push rod, it's still hollow and filled with oil. What ever means you use to reduce the volume of oil in a push rod is going to increase the mass of the push rod. Am I missing something here?Less oil in the pushrods = less overall weight associated with the pushrods.
Anything you can do to make the valvetrain lighter like with restrictor pushrods will help when it comes to valve float caused by v/spring issues.
But i would not think the small amount of weight saved with the restrictor pushrods may not be much of a factor unless the pushrods themselves are much lighter too. Then collectively less oil and less material in the pusrods themslves may add up to enough of a weight reduction to help avoid v/float.
Scott
I think you need to move your rev limiter up a couple of hundred rpm. If you are shifting at 6200 rpm and the rev limiter is at 6400, you are likely already getting into the rev limiter control. Almost certainly are at 6300 rpm.I make peak power at about ~6000-6100rpm. shift at ~6200-6300rpm and have my rev limiter set at 6400rpm.
Mass reduction on the valve side of the fulcrum is more critical then on the lifter/pushrod size.
