so i'm starting to pull my transmission out....i can't see how many bolts hold on the Hurst shifter...its up too high....do i need to remove the engine motor mounts and have the transmission tilt back ?...think i need to unbolt the shifter console?
Two bolts hold the shifter head to the mtg plate, one long 7/16 bolt and one long 3/8 bolt. Both attach the shifter head to the mtg. plate.so i'm starting to pull my transmission out....i can't see how many bolts hold on the Hurst shifter...its up too high....do i need to remove the engine motor mounts and have the transmission tilt back ?...think i need to unbolt the shifter console?
EXACTLY as Philip described it above!That is the hard way to do it. It may be difficult to get back in.
This is how I do it. Remove the driveshaft and shove a yoke or plug into tailshaft, remove the distributer cap, remove the shifter handle and boot, unbolt pipes from headers, unbolt trans mount, unbolt crossmember, jack up engine under oil pan, remove crossmember, lower engine, unbolt and remove transmission.
