1 - 1 of 122 Posts
Did you use offset cross bars on this rebuild? The ones that attach to the upper control arms? Is it important to use offset versions? or can you live with standard ones? What real gain do you get with offset?
Only need the offset ones if you are having frame sag problems and have issues getting it up to alignment specs.
1 - 1 of 122 Posts
