One last check before a yard drive was to dump the differential fluid and check things out. Surprise…never good to find heavy metal in the lube.
it looks like the center pin has some distress. The gear damage contained to pinion gear. The metal looks like remnants of a pinion oil seal.
What do you see? Can I clean it well and run it ?
