http://www.brillko.se/LM1-NOS.GIF
http://www.brillko.se/LM1-NONOS.GIF
look at these picks and you will se how much it pendning.
I dont feel this so much under the run, but it dont answer to any more nitrous. Running faster with 100hp than 225. So i looked in my logs and found this.
Runs perfect without NOS as you can see on the other pic.
Running Powershot N20 and Cheater Fuel Solenoids.
A BG 220 fuelpump and regulator. AN10 delivary and AN8 Return.
Can fuel solenoid Fluctate? Will it do so before Nitrous starts fluctating. Have 13.8v+ whole run.
Can a N20 Plate under my MAP-sensor give it signals so it thinks i have 2psi or more BOOST?
If it thinks so i can map these curves. because, they are lean. ( I dont use any boost)
Hoping for some answers because its not very fun ;(
