Hi guy's i am sure this will be an easy one for one of you out there.
My friend is restoring a 70ss 396 which he wants to keep the stock points ignition for shows etc which is where the problem is so lets not get into the electronic conversion for now wasting your time suggesting it because he is a purist and would like to stick with it for now.
The problem is that 9 times of ten you go to start the car there is little or no power to the coil/ign so of course it wont fire.
There is little or no voltage at the coil when chekced with ign switch on or when cranking the motor,coil is new too.
But if i hit the coil with 12 volts from the battery the car will fire up just fine and runs decent but the motor does drop a few hundred rpm when the 12 volts is removed from the coil after it fires up and runs a little shabby too untill you get it off idle so i think it's runnig off the alt which has lower power at idle.
Now all the other eletrical items work fine in the car so what i am hoping to do is just replace the primary ignition resistance wire and not waste tons of time trying to hunt down the problem/s with the original wire,kind of a bypass thing.
So my questions are as follows:
1)Could a bad ignition switch cause this problem?
If yes how can i test for thie without buying a new ignition first?
2) Am i coerrect that the stock points ignitionr runs on approx 9-9.5 volts at the coil?
3) Where should i hook the new primary resistance wire for power,from the fuse box or where?
4) Where can i get a new length or primary resistance wire to do this with or if it's not available then could you give me a brand & pt# for a resistor that would drop 12 volts to the 9volts needed for ignition when the ignition switch is turned on the then twisted to the cranking position to start the motor too.
5) It did Does this with the old and new starter so i dont think its an issue with the wires at the starter solenoid.
The bottom line is we just want to get the correct amount of pwr( 9 volts?) to power the ignition when cranking the motor,also to be there after you release the ign switch after the motor fires,and then turns off when the ign swithch is shut off to stop the car the easiest way possible so where should i get my power from to do this? And where do i get the primary resistance wire i need or which resistor pt # will drop 12volts to 9 volts for the coil?
Thanks....Scott
Thanks....Scott
