Hi everyone!
I'm about to take my camino project for its first spin around the block.
Ive dropped a 396 in it and a th400, some custom suspension and some new interiors. I've had the car for almost 3 years now and never driven it...!
I'm really close now but I've been having some problems lately with the engine not running on all cylinders.
I set the timing the other week at 16 idle, 36 total and it ran great!
Then when I started it up again for a testdrive and it ran really bad.
Checked all the plugs with this kind of tool that you put on the cable.
I found out that cylinder 1 had a really weak spark!
I swapped the spark plug and the cable and it didn't do any good.
So I guess it has to be the distributor then..?
Took of the distributor cap and found grey spots on the brass surfaces and thought that I had found the problem.
Got most of grey surface of with some sandpaper and put it together again, but still having the same problem! Weak power on cyl 1!!
By the way it's one of these electronic distributors...
Anyone got clue?
Should I just buy a new distributor?
Anyone got clue?
