Guy's I'm attempting an at home alignment, just want some more experienced eyes to check my procedure.
Basic order of adjustment is 1. caster, 2. camber, 3. toe
Positive caster is achieved by adding shims to the rear UCA bolt. I checked total caster by adding the sum of two measurements, one at 20* left turn, one at 20* right turn. (lets say for example 20* left was +1.2* and 20* right was +1.4*, total in this case would be 1.2+1.4=+2.6* caster) One question here, how important is the 20*? Would it be ok if I just did equal turns of the wheel left to right?
Camber is measured using the same technique, but with the wheels facing straight ahead. Camber is adjusted by adding equal shims to both UCA bolts.
Toe - last but not least, I fabbed up some brackets that mount to the wheel to check for toe. Just use a tape measure to get to your desired number.
Thanks!
Thanks!
