my system was rebuilt in 2006 using NOS POA valve
system is all GM except the new hoses & R-12
used to run 38* duct temp right after the rebuild
this summer it is running about 45* duct temp during day with ambient 93-100*
pressures are 30/250 with engine/rad warmed to 170*
drops a few * to 40* if driving (better airflow thru condensor ) at cooler nite 83* temps
what should the operating pressures be?
i know the POA is calibratetd to hold 29 psi but dont know if the operating pressure should also be 29 ( if so i am only 1 psi high at 1500 rpm... goes to about 33 or 4 psi high at idle) but i dont knw that the actual operating pressures should be.
anyone know for sure?? for a stock GM system???
TIA
TIA
