We I finally did it! I was planning on building up a 2 bolt block but found a nice deal that Notalent(Brandon) had for sale from ATK racing engines. Here are the specs:
4 bolt block.....040 over
Scat 9000 4.25 crank
Scat 4340 I beam rods/arp bolts
KBF Forged pistons...+18 dome
Howards hyd roller..294/302....236/242....620/620....112
Lunati 72331 roller lifters
SA double roller chain
He said it made 600/605 on the dyno with Edelbrock Perfomer rpm heads and a Quick fuel 780 street carb. Im hoping the AFR 315's and larger carb picks the power into the 650/650 range. Looks like I might run an RPM air gap instead of the Vic Jr for this build just seems to fit the build better. So here is the plan...what do ya think.
491 cid
10.2 to 1
AFR 315's
Hyd roller...294/302....236/242....654/620(1.8 intake).....112 lsa
RPM air gap
Carb...unsure....HP950/HP1000/Regular 850 DP...current have HP750 street
2"x3.5" headers
3" mandrel exhaust/X pipe
MSD probillet with vac adv/6AL-2 digitail programmable
Holley Billet mech 170gph pump
491 cid
10.2 to 1
AFR 315's
RPM air gap
2"x3.5" headers
