Hey guys,
I've been having an issue with my jeep for some time, but havn't looked at it or drove it much since i bought the trans am, but now its winter, and im going to need something half decent to drive in the snow so i need to fix this.
my issue is, when i turn the key sometimes i get a click, but 95% of the time i get nothing like a dead battery. I have power to everything.
Now when i jump the solenoid on the starter with the key in the on position, it fires right up.
at first i thought it was a neutral safety switch, and it helped for a short time, but had no start again. so i replaced the starter and it worked for about a thousand miles. then no start again, so i replaced the starter again (remans with life time warrantee).
i am lost as to what it could be.
the only thing i did not try was a new ignition switch
vehicle is a 96 ZJ grand cherokee with 4.0 I6.
what should i check, or what are you ideas?
thanks.
Aaron
thanks.
Aaron
