1 - 1 of 2 Posts
OUChevelleSS
Discussion starter · #1 ·
Well, I got the special tool from Jegs and stuff for oil priming. We have the drill (set on forward) and it's filling up oil to the lifter galley. But, no rockers are oiling yet...did see a few bubbles come out of one. I'm doing this with the intake off so I was sure I'd see everything. Anyway, the lifter galley gets a lot of oil, but no rockers...they are solid lifters and I have roller rockers up top. I pretty liberally coated the ends of the pushrods with moly lube and EOS for good measure. So, I'm almost positive the bottom end is getting oil, just not the top end. Is this okay and will work itself out on startup? Do I just need to hold the drill a few minutes longer? I also put 15W-40 oil in there, maybe it will take a ibt longer because it is thicker? Thanks guys..
Save
1 - 1 of 2 Posts
