I pulled my oil pan, well dropped it as far as it would go because I forgot to lube up that little strip that lines against the bottom of the timing chain cover, it leaked oil. Fixed that and I started putting things back together the larger bolts that go on the ends of the oil pan, the one on the front driver side got stripped somehow and wont go back in. I dont mess with tap and dye or re-thread kits, I think thread holes is tedious work and im bad at it! Should I roll it into a shop and have them tap it up a larger thread? They wouldnt have to pull the engine would they?
