Discussion starter · #2 ·
well guys i got all my lines in but can not figure out how the line goes from the proportioning valve to the passenger side brake, it just looks like its bent all wrong i may just try and bend my own line from end to end. does the line go on the front of the cross member or behind, its been so long since i striped the frame.
When I converted a '72 to disc brakes (not a '67) I had to rebend the line to the right front brake to accomodate a combination valve that was a bit longer than the original distribution block. I suspect that you have a similar challenge. I took the part of the line that is on the back of the front crossmember and put a lazy "s" bend in it to use up the extra length.
Where did you get your kit from? I got mine from Right Stuff for my 66 non powered front disc conversion. Let me know if pictures from mine will help, you will have give me your e-mail address, I am not sure how to post pictures here. Let me know.
Jesse
