1 - 12 of 12 Posts
Racer613
Discussion starter · #1 ·
I have a newly put together 350..mildly built (about 320hp) also have a 400 t trans...ok, there is no rattle when I start it, no rattles when I warm it up, and no rattle when I take my foot off the accelerator. And there is no rattle when I give it a good amount of throttle, but when I am bareley pressing the gas to keep up with 55-65 mph traffic, there is a distinct but low rattle coming from (seems like the meet with the trans and engine) I dunno what it is and its driving me nuts! Any input would be appreciated
Save
Sounds like it could be detonation. If it is, it could be your timimg is too far advanced. A simple test for this would be to disconnect your vacuum advance and plug off the port on the carb or manifold where it was connected.
Now take it for a drive and see if the problem is gone or less pronounced. If so, check your initial timing and back it down some. If you have a way to check your timing curve see where your are at 2000, 2500 and 3000 RPM. You should max out at about 34Âş or 36Âş total by 3000 or so. If you are above that, adjust your initial timing down some and check again.
You may have to adjust your idle as you change your timing. Once you have made a change take a test drive and see if that improves the situation.
If none of this helps, you need to get with someone who knows performance engines and have them give you some help figuring this out. Whatever you do, don't ignore it if it's detonation because you could slowly destroy that engine.
BTW - very slight detonation is sometimes exceptable under very light throttle to maximize gas mileage. I prefer not to have any on a performance motor.
Anyone got other ideas?
Troy.
Save
what kind of gas are you running? i get that occasionally with my 97 Ram if I get a bad tank of gas that has low octane. It is possibly a spark knock. Try putting some octane booster in it to see if that helps.
Save
Discussion starter · #5 ·
It could be detonation...I have to check the timing again, I try to run 91-92 as much as I can, but I have put 89 in it for $ reasons...I guess I will just pump 91+ from now on and fix the timing. Thanks fellas!
Save
Discussion starter · #6 ·
Well, I pumped 92 octane and ran an STP fuel addative that was supposed to boost octane to 100?? Tried the freeway and the noise is still there...almost sounds like a loose bolt or something....I am vexed :mad:
Save
I don't know agreat deal about pinion angle, but i know it can cause vibration sif it's off some. The name refers to the angle of the transmission and rearend. Say the trans is 5* down, the rear should be 5*up so it keeps the drive shaft straight and good. Someone else can explain better but a mismatch can cause vibrations at higher speeds.
Discussion starter · #11 ·
I am located in Tucson, AZ 85741 pm me and I'll give you my # if you still wanna hear it. Thank you!!!
Save
Discussion starter · #12 ·
Well, it may be a wrist pin.....the guy just rebuilt my damn engine.....
Save
1 - 12 of 12 Posts
