The Powershot is non-adjustable. It will work fine if you plan on just teeing off the fuel line right to the solenoid, but will be very rich. If you wanted to optimize the tune a little bit, you could use a seperate regulator and flow the fuel pressure to a lower setting. This is how bigger systems are setup. I cut my teeth on a Powershot back in the day, it worked ok. My car picked up 3-4 tenths in the 1/4. I eventually upgraded the plate to an adjustable unit, and then bigger solenoids. As far as timing, the 2 per 50 rule is a good starting point, some say the first 50 is free so to speak. The plugs will tell the story, but you may find that it won't require much timing out at that level. If using pump gas, definitely pull a few. Don't use extended reach plugs, use a NGK 5671A-9 to be safe. Get a bottle heater and a gauge, the pressure is key. Any lower than 900psi and it becomes really rich. Weigh the bottle after a few runs, when it loses 5 or 6 pounds, you won't be able to get the pressure up, and will have to get it topped off or run into the rich condition again. The stuff is addicting! Cheapest bang for the buck out there. Have fun!
