Nitrous and rev limiters
1 reading
10K views 15 replies 12 participants last post by  onebad82z
I am just toying with the idea of putting a smaller nitrous kit on my car ( maybe 150 HP), just to see what it will do. The previous owner installed both a "nitrous grind" cam and "nitrous" convertor and its mostly a street car, so that got me thinking...
I installed a rev-limiter, and I was wondering if hitting the rev-limiter with the nitrous "on" is a bad thing? It seems like it might be a receipe for disaster if the tires spin once the nitrous comes on, and the cylinder doesn't fire, but fires the next cycle...
So, with a rev-limiter, am I going to need a nitrous controller that will shut off the nitrous several hundred RPM below the rev limiter?
Or is it nobig deal?
#5 ·
:yes:
I run a 200 shot on a well worn 468 with a msd6a and soft touch rev limiter I have hit the rev lim, more than once on the spray no problem. Not saying it's a good thing but it happens with my set up.
You've been lucky. I've seen from the least, a header blown off to the worse, A head come through the hood.... Funny thing is, The header incident was on a 150/200 two stage (both on) and the head escape was with a single 100 shot... Not sure on the limiter types with either car..
#3 ·
good question. Having been a nitrous racer for 10 years, I would suggest installing a MSD window switch. They are relatively cheap and easy to install. This will allow you a perameter for the nitrous. Good rule of thumb is to set the second chip in the window switch 200 rpms less than the rev limiter.... You'll be glad you installed it...
Chad
#6 ·
Move the rev limiter. Rev limiters are to be used in the event of a driveline failure. A rev limiter is not supposed to be used 200 rpm above where you want to shift it at. If the engine can run clean to the rev limiter, then raise the rev limiter.
#7 ·
this is a great question that brings concern to my own combo. i use my rev limiter as a safty catch because i run a cast crank and the 3/8 rods. i have spun the engine 7000rpm before when i was chasing an ignition problem and didnt have the limiter on. the head/cam combo wants to rev more than the bottom end should go. i have though about a 150 shot but tire spin scares me. what is the solution?
#10 ·
75 / 100 shot
#11 ·
Why is it bad? Unburned fuel goes out the exhaust. Window switch is a great idea, For 150 I wouldn't waste to much money on window switches, and exotic controllers. Install relays for selonoid activation, maintain bottle pressure, run seperate regulators for nitrous and carb... have fun with it. You could gain 1.0 and 10MPH
Limiters aren't only used for overreving.
#12 ·
These guys that use the rev limiter to shift are DUMB
They leave then BOP BOP BOP shift and so on
The rev limit is where your at 7000rpm in low gear and drive shaft fails or tires spin so you dont go 10,000rpm+ not to shift
Yes they can be used for leave rpm and burnout protection but you dont need it if you do the burnout correctly and not zing the engine RPMS to the max
We can do a good burnout and never go over 6000rpm but we shift at 7800rpm
