I’ve seen some other posts about HVAC and know there are some pros on this forum so I’m looking for some advice.
I’m finally breaking down and putting AC in the house. Been here 40 years and it hasn't been an issue until that last few years. Hotter weather and older age are not a good combo.
Our existing furnace (Carrier) Is pretty new so we’re going to keep it. Our house is 2 story, semi-open construction, 2400 sf, master bedroom downstairs, all other bedrooms upstairs. Currently we keep all the upstairs registers closed since no one is ever up there. Northern California location so basically zero humidity.
I can tell you that we are not AC people. We prefer open windows to AC so we will only run it when it’s over 95-100 for multiple days and the house doesn’t cool at night.
The reason I’m asking is we’re getting quotes all over the place. Not so much price all over the place but equipment. 3 ton, 4 ton, single stage, two stage, 14 SEER, 17 SEER, dual zone, left handed (just kidding on the left handed).
I understand the tons and really there isn’t much difference between 3.5 and 4 tons but what about the single vs 2 stage and the dual zoning (not an inexpensive adder)?
And one guy said it’s fine to put a lattice type fence 12” away. Another gut said a minimum of 24” all around. To an open lattice fence? Seems nuts.
They also all say “plastic pad”. Does this go right on the dirt or should a make a DG pad for the plastic pad?
Any other things I should consider before deciding?
Plus I've been quoted Carrier, Day and Night and Bryant, which I understand are all from the same company anyway. Is anyone better than the others or one to avoid?
