I was reading a book the other day about Trans-Am racing. One team's main car was down so they built a '64 Tempest and it actually was moderately competitive even though it was a bit larger than other cars in the series at the time such as Firebirds, Camaros, Mustangs and Javelins. The owner of the Tempest was quoted as stating that later in life he tore into the Tempest only to find it had been modified by Herb Adams in a special Pontiac project which helped explain why the car handled so well. What he found is that the Adams' engineers had found a way to dial two degrees of negative camber into the rear axle which really helped plant the car in turns.
How could you build negative camber into a solid axle? I would assume you would basically bend the axle housing tubes two degrees vertically to accomplish this. BUT, wouldn't doing so cause trouble where the axle shafts mate with the differential thus causing premature mechanical failure at that location?
