Need some advice on a 1969
821 views 2 replies 3 participants last post by  31 chevy
I am going to Check out a 1969 Chevelle SS 396 350 hp, I am told all numbers match except the diff, what should I be looking for on this car to verify that is an SS?
#2 ·
If it's truly a numbers matching car, which most people take to mean at least the engine and transmission are original to the car, the engine and the transmission will have a partial VIN stamped on them that should match the plant & sequence number of the car's VIN plate. Where the partial VIN is stamped depends on the assembly plant. Atlanta & KC engines are normally stamped on the rough cast area by the oil filter while other plants on the the engine pad with the Tonawanda engine ID stamp
http://chevellestuff.com/1969/chevelle/engines/vin_location.htm
Engine components should also be date correct for the engine itself.
