Hello, I have just dynoed my 468 BBC and need to get a torque converter. I will give as much info for everyone and would appreciate what your running as well with any input.Everything is appreciated. I have a torque converter in mind but need some added knowledge from guys already running.
468ci BBC with a B&M 250 supercharger
Cam specs: 113 lobe seperation
254 int 260 exh @ .050
661 int 668 exh lift
Turbo 350 transmission w/ pro rachet b&m shifter
4.10 rear end gear
30" Mickey Thompson ET Street tires
Dyno numbers:
2800 rpm 582 ft-lbs 313 hp
3000 rpm 595 ft-lbs 340 hp
3500 rpm 620 ft-lbs 413 hp
4000 rpm 638 ft-lbs 486 hp
4500 rpm 638 ft-lbs 547 hp
5000 rpm 631 ft-lbs 601 hp
5500 rpm 602 ft-lbs 631 hp
6300 rpm 546 ft-lbs 665 hp
4.10 rear end gear
Dyno numbers:
