well i went to go fool with my timing curve today. i have the accel 31041 kit. i had the medium weight springs in there already. car has too much advance too early and not enough total up top it seems because it dies up top. vacuum was around 13". i went with the heavy springs and the car totally changed. when i put the heavy springs in, the car is a dog down low and runs better up top. it also runs about 10 degrees hotter. vacuum was up to about 16". i then installed one medium and one heavy and it was somewhat of a compromise, but i still lost power up top and down low compared with the other setups. vacuum was up to 20 inches at idle though. im trying to figure out how the heck i can tune this curve correctly. should i try a different kit?
16 degrees initial with all setups.
