For the first time ever I had the chance to put the L79 on a chassis dyno. On the dyno it felt horribly sluggish. Per the operator's process I would run it up to about 3000 then floor it and shut down when he said to. Using this method we couldn't get more than 5800 RPMs and on anything above about 4800 it felt like someone was stuffing a sock down the carb. On the road, it pulls really hard from 5000 up to whenever I feel like letting off.
Over the past few days I replaced the 40 year old valve springs with new ones. They are the same rating so no changes were made there. I have Pertronix in the distributor running 12 degrees initial with 36 total in at about 3500.
On the dyno run sheet it shows 0.8 inches of vacuum at 3000, climbs to 1.3 inches at 4000, by 5000 it's at 2.3 and when we shut down at 5800 it was at 2.9 inches with a peak of 3.0 inches at 5700. The dyno operator says the vacuum should be below 2.0 for the whole run and that it would be better to have it around 1.5 for the whole run. What he thinks may be happening is that the secondaries are opening as they should, then as manifold vacuum builds, it is pulling the secondaries closed part way or all of the way thus killing top end power.
I've never owned a dial back timing light but a friend had one with him. After my dyno run we hooked up his light and confirmed I have about 36 degrees of mechanical in at about 3500 BUT, it doesn't stop there! The mechanical continues to climb and we saw as much as 52 degrees mechanical at around 5000! Can this at least partially explain the growing manifold vacuum reading? Regardless, I do need to find a way to limit the mechanical advance. The factory curve is very slow and long with maximum mechanical not arriving until past 5000 so I added softer springs years ago and they provided the all-in-by number I wanted but I never thought to check if the mechanical advance went beyond that.
In driving the car on the street, which I did as soon as I got off the dyno, it runs great, pulls like a freight train (well as well as a 327 can pull) from 5000 and revs like a wild thing until I take my foot out of it.
I did notice that my factory tach reads fast compared to the dyno tach. At idle it is fairly accurate but as the RPMs go up the factory tach reads much faster than the dyno. When I shut it down at 5800 the factory tach was pegged beyond 6000.
The carb has a slightly lighter than stock spring for the secondaries (yellow). I found after I put in a K&N filter that I could feel the secondaries open and that they opened later than they had before. By changing to a lighter spring it felt like it's old self.
The A/F ratio was pretty good at 12.7-12.9 for most of the run. The peak HP arrived at 5600 which meshes well with the factory power curve. The operator said I could pick up from 10-25 horsepower if I can cure the vacuum (intake restriction) problem. The carb is a 585 cfm Holley and is just like the factory delivered it though I don't recall the jetting or PV settings but then those settings don't seem to be the problem.
Any ideas?
Any ideas?
