I think the burns merge collectors are designed for open headers?
I'm using a 4 inch dr gas x pipe and its only about a 3 x 1 7/8 hole in the cross over so I think we got the venturi effect going on there lol.
I read somewhere for every 1/2inch you go up on the collector diameter it raises peak torque by 500 rpms ?
If this is true maybe it would help me get some consistent 60s.By softening up the bottom a bit.?
I have a small cam and heads for a 555 and a beastly 8 inch ptc converter with 9inch tires. Out of 30 are so runs 20 have been aborted due to traction issues.
It sucks to drive the car 70 miles pay the track and for gas only to get horrible 60 foots and abort most of my runs.
I hope they don't leak? when done.
Wow, does this sound familiar, except I only have to drive 45 miles. Just curioius, are these trips to the track on sanctioned event days or something like Friday night street nights? JMHO, I kinda doubt any change in header collector size is going to effect the torque curve enough to drastically change the ability of the car to hook on anything but the best track conditions without a true dedicated drag tire (here come the arguments). I fought this with a 469"/rec port/3000 stall combo. Never knew if the car was going to leap when I nailed it or it was going to be an on/off throttle deal at the light. Frustrating to say the least.
Can't comment on the collector size, you may even see a nice increase in top end just going to a 3.5" collector over the 3", then out to the 4" pipes as opposed to 4" all the way. Those Hedmans are typically a nice fitting header, but the 3" collector does choke it down some coming off of 2" primaries. IIRC, those are not equal length primaries?
This may get off topic, not meant to be. Closest I've ever come to getting the car to launch on the Friday Nights was when running a vac sec carb with a high rate black secondary spring, but, the car was always down 1.5-2.0 mph over a DP, which we just assumed was due to the carb not opening all the way. Holley used to make a HP1000 in a vac sec, was popular with the Mopar guys. Saw one on RJ last year that I almost bought to try. Prior to going belly up, BG had expanded their line of HP style carbs to include vac secs all the way to their 1000 cfm carb, were marketed just for this situation.
That 8" PTC converter is probably not helping things either. I went with TSI 10" extra low stall N2O converter (2700-2900) behind the 540" in an attempt to get the car moving well below where the torque curve gets real fat. Tall order considering how these motors build huge torque right off idle.
