I've done it before and have gotten along fine. But now I'm having trouble keeping the line from slipping in the clamp. Every single time I try to begin the 1st flare, the tube slips. I have the clamp tightened all the way on both ends. I tried wrapping the tube in a layer or two of duct-tape, not figuring it would work and...it didn't help.
I'm trying to make the flare in previously installed brake line tubing (not Stainless). Could that have something to do with it? I even used steel wool to clean up the outside before putting on the clamp but no help. Now that I've thought about it, all the previous successfully made flares I've done have been in new tubing. I'm trying to just replace a section of the line this time.
Which leads me to my next question. Surely there has got to be better double-flaring tools for the home user than the relatively cheap clamp and twist the cone shaped thing down type. Is there anything better out there, but not so pricey? Maybe around the $50-75 mark that is easier and more reliable?
Thanks,
Tom
Thanks,
Tom
