Sorry it took so long to get these numbers...
Snowflake on #2 intake runner with W in center.
Behind carb....3933163 with large GM lettering below it.
Another related question....the hose connecting my PCV valve to the base of my carb is collapsing on deceleration and at idle? Its not "whining" under deceleration since it nearly squeezes itself shut.
If I pull the valve out of the valve cover grommet its fine, however if I remove the valve from the end of the hose is sucks hard. If I cap it with a finger the hose will collapse at idle and expand under increased throttle. The whinning when the hose collapses is ANNOYING.
Could this be an improper picece of tubing the prior owner installed, perhaps a more rigid walled hose would be better?
