1 - 8 of 8 Posts
SS_Dave
Discussion starter · #1 ·
I had a lifter that would not de-pressurize. In other words, it was stuck fully extended. It was clattering because the proper lash could not be set. I decided to start the engine and back off the rocker until it clattered and then tighten until clatter goes away and then 1/2 turn more.
Seemed to work ok. Drove about 10 miles and parked it. Next morning I start it up and lifter is clattering again. ( Clue #1 ignored ). I promptly pull the valve cover and see it is loose.
I thought maybe the poly lock just backed off because I didn't get it tight enough. ( deception #1 ) I readjust same way. Problem seemed to go away. Drove to Crashes house and car is popping out the carb any time I give it any gas.
Seems to be missing also. pulled valve cover and found intake rocker going up and down about 1/4 inch. Some clacking. Tried to readjust, and it became painfully apparent that a lobe was gone.
450.00 later I have a new cam and lifters.
I pulled the heads to check the cyllinder walls and found some scoring on #1, #2 and #3. Some very minor scoring on two others and nothing on the rest.
Any suggestions on what to do would be appreciated.
Moral of the story:
Do not assume that a hydraulic lifter will compress when the engine is started. If you cannot get it to compress prior to starting, raplace it.
Save
Man that sucks,I know you have been doing alot of work on yours.
A guy also might want to also check to see if push rods are straight to.
Save
Yup, roll them on a piece of glass and check the ends for mushrooming, and most importantly Dave, replace it with a solid flat tappet and make some more torque and simpler maintenance!
Save
Discussion starter · #5 ·
Too late Gene, I already have the cam and lifters in it. I did think about a solid lifter, but decided to replace it with the same cam. It was supposedly matched to the intake by Edlebrock.
I don't see any reason why I couldn't throw some solids in there after the cam is broken in, do you?
Save
Well, I was being facetious Dave, I figured you had the back-up cam if not in, then sitting on the workbench already.
Dont do it. Ask BLT4FN about the deal. I adjsuted his valves 2 or 3 times and they still clacked like hell. You can do it, running about 3-4 thou lash, but its not copasetic at all.
Save
Discussion starter · #8 ·
Oh, in that case.. :D
Ya gotta keep smiling.
After all, it IS a hobby, right?
Save
1 - 8 of 8 Posts
