Having some difficulty with the assembly of the Hood latching mechanism with the supporting bracket underneath and the front V shaped bar. See pictures.
The hood latch is swinging back into the condenser coil damaging the fins and sits back against the coil. Is there any way to adjust it away from the condenser coil?
When tightening all of the bolts, the top V shaped bracket support is pulling up. It is interfering with the hood. Is there an adjustment that I can make? Don't want the bracket support to hit the hood damaging the paint on both of those parts.
Any of your comments would be much appreciated.
Thanks in advance.
Randy
St. Louis, MO
Thanks in advance.
Randy
St. Louis, MO
